Well, if any of you remember, I recently added AFR heads, MSD, and a cam to my original 289 and didn't quite get the performance I was hoping for, in fact it only netted me around 25 RWHP on the dyno. Because I didn't want a $1,300 dollar set of heads to wear away on an engine I wasn't really happy with I had Ford Performane Solutions in Anaheim build me a Roller 306 and they used all of the goodies they could off the 289 to keep the cost down. So, I pulled the 289, took them everything they could use, got a good deal on a block and crank from 66P51GT, and they supplied the rest.
So now I have a Roller 306, balanced & blueprinted, port matched AFR 165's, Weiand stealth intake, Holley 670 SA, Main girdle, windage tray, crank scraper, Full MSD, Powermaster 1 wire alt, custom grind cam (can't remeber the specs) lift is 512 & 520, 7/16 rocker studs with RPM full roller rockers, forged eagle I beam rods, TRW forged alum. pistons, flow kooler water pump, Canton 7qt pan, Blueprinted Melling oil pump from Precison pumps, TCI street fighter C-4 with TCI 2400 stall. Add in a few bucks for misc. and there you have it. I feel like a new Dad with this thing!
Anyways, I finished the installation yesterday. I was able to do everything myself with the exception of putting the hood back on. That is a two man job...period. Taking it off by my self was a PIA though. Took me 5 total working days to pull the old and install the new... I am tedious. I had a hard time getting the distributor to line up directly with the #1 plug on the cap, spent about 3 hours on that, but besides that everything else went really well. Fired it up and she runs! I definatly need to tune the carb because it is way fat, and I have to work out the timing. It runs best at about 24 degrees, which I think is way too high, but it dies when I turn it down to 14. I'll work on the fine tuning this weekend.
Anyways...the 306 is in it runs and I saw no leaks after a 20 minute idle and 30 minute cruise. I think I can safly say...SUCCESS! ohh, ya.....I did open it up once just too see, and even though it is fat on the carb, WOW. It is going to be fun.
It is FINALLY want I've wanting the engine package to be and it is fun!
