315/35 nitto's AND tailpipes...pics
BERT306
75
Alot of people wonder if 315's fit on a fox: YES they do. I didn't think my tailpipes would fit but, YES they do:
and some random pics before tailpipes:
Look Its Aaron said:
Please give some more description of your set up. What axles did you use etc...
Stock length ranger axles, no quads or spacers. I had to do some clearancing on the inner fender w/a BFH. Did not roll the outer lip at all.
Up front i used 5/16" spacers w/lincoln rotors and a 245/45 tire.
:SNSign:
17X9's front AND back. The nitto's run small so i don't think i'd get a BFG drag radial on there.
Flowmaster Cat-back, and hacked-up factory springs (I immediately regreted that decision BTW) Lookin to get some Eibach pro's and some strange adjustable struts/shocks.
Thanks for the comments!:Word:
Here's the only rear pics i have other than the one i already put up:
And before tails and hackin o the springs:
Here is a short walk around vid i made awhile back--> http://videos.streetfire.net/Player.aspx?fileid=DE101D14-EF46-47A7-A737-CDD25A543688
Here's the mod's:
stock short block bored .030
Windsor Jr. iron heads
Crane 1.6 rockers
X-303 cam
24# inj.
Eddy perf. rpm & 1" spacer
BBK 70mm TB & EGR
C&L 76mm MAF
MSD 6AL ign.
MSD coil
Lontubes, h-pipe, 2 chamb Flows
NOS 125hp dry shot (unused now)
V-1 S-trim @10lbs w/ 10 rib
AFM power pipes
Mondo Bypass valve
Spec Stg 3 clutch
alum driveshaft
3.73 gears
South side upper + lower control arms
5 lug conv. (ranger axles, lincoln rotors)
Weld in Subframe conn.
6 pt cage
Jeg's sport seats
I think thats all? I should have just updated my sig instead:rolleyes:
hmm, I may be wrong but I dont think that roll cage will pass tech. The bars look to be way too low.
I don't think it's fast enough to require a cage anyway. It was in there when i bought it. Any higher and i would have cut them out already.
