What do you think this would run 0-60 and 1/4.....
331 n/a (stock block) probably 10:1
forged pistons, cast crank
trick flow top end kit (track heat)
70mm throttle body
76 c&l
30lb injectors (might need bigger?)
Also, same setup but with a vortech v-1 or paxton 1000 (or sl) only running 8 psi. Lower compression also
Thanks!
70mm throttle body
76 c&l
Thanks!
