331 0-60 times
ras50gt
200
What do you think this would run 0-60 and 1/4.....
331 n/a (stock block) probably 10:1
forged pistons, cast crank
trick flow top end kit (track heat)
70mm throttle body
76 c&l
30lb injectors (might need bigger?)
Also, same setup but with a vortech v-1 or paxton 1000 (or sl) only running 8 psi. Lower compression also
Thanks!
So I should probably go with a 75mm throttle body. You think the 76mm c&l is too small? What size injectors do you think?
420 rwhp with or without the 8 psi charger?
Is the street heat kit too small for a 331?
1: Yes
2: No but I would get a Pro-M or Lightning one
3: 42
4: With the charger420, prolly 320~ without
5: No
Swap out camshafts, upgrade the "bolt-ons", and slap on the supercharger.
You will be getting into block splitting power. 450-500 RWHP...
With some drag radials (assuming traction), you will be in the high 3 - low 4 second range.
Ive had both and since the ProM is larger it has the ability to flow more air :shrug:
Am I wrong?
Also the C&L has problems with an open air filter in the engine bay because of cooling fan turbulence, just throwing that out there :stirpot:
