331 combo
  • Thread starter Thread starter airbag
  • Start date Start date Nov 11, 2005
airbag
49
hebron, indiana
Nov 11, 2005
  • Nov 11, 2005
92 gt 331 dss rotating assembly, stock block, iron gt 40 (ported), cobra intake, e cam, 1.7rr, stock tb stock inj. think this tb and inj. can keep up? do i need better heads? or should i go with a 306 rotating assembly, need suggestions. thanx
I
IntenseBlue
946
  • Nov 11, 2005
Definately gonna need 24lbs injectors. TB will pick it up at least 10 horsepower with that combo, but it's not gonna make the engine run like crap if you don't change it. Heads will be OK.
95COBRA241
339
Delray Beach, FL
Nov 12, 2005
  • Nov 12, 2005
Why would you want to go from a 331 to a 306? Doesn't seem to make sense. The combo you have is good for a street car. The car is getting much more air so you need to take care of fuel concerns i.e. fuel pump (255lph), injectors (24lbs), MAF, and later....a TB
NosPony
278
Canton, Il
Nov 12, 2005
  • Nov 12, 2005
If it was me why not go with the 331. Then later upgrade the tb and injectors. Easy to change both of them.
Just my .02$
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
