Hi there,
I bought an unfinished 1994 GT project and would like to try to set this car up right so it will run good and achieve some nice hp numbers. Currently the car runs fine. I had to have the vortech v2 s sent out for new bearings and had them instal an upgraded si impeller. I have asked this question to a few shops and have got different answers. Some have told me to change the fuel pump, others have told me the fuel pumps are fine and to change the injectors to 60lb and change the mass air to 90mm. Any suggestions are welcome. This car is primarily for the street with occasional strip usage.
Here is the current set up:
DSS 331 stroker
anderson motorsport cam
Trick Flow twisted wedge heads with 190cc
trick flow street heat intake
vortech fmu (which i think can be deleted)
42LB injectors
aeromotive fuel pressure regulator
bbk 75 mm throttle body
air prom 76mm mass air
egr delete
vortech v2 si with 3" pulley 8 rib pulley set up
anderson power pipe
bbk shorty headers
bbk off road h pipe
2 wide band 02 sensors
flow master 3 chamer exhaust
wallbro 255 lph in tank pump
t rex in line pump
What would you recommend changing in this set up? Thanks for the input.
DSS 331 stroker
42LB injectors
egr delete
anderson power pipe
bbk shorty headers
bbk off road h pipe
t rex in line pump
