  • 1994 - 1995 Specific Tech
347 Combo
  • Thread starter Thread starter doobsstang
  • Start date Start date Aug 2, 2006
doobsstang
92
Pembroke, NH
Aug 2, 2006
  • Aug 2, 2006
I am currently trying to make a combo that will make about 400rwhp. I want it to be a 347 Stroker. Any suggestions of what kinds of heads, intake, or cam? I am thinking about AFR 185s but how much more power will 205s give me and with those will it be good for the street? I am kind of lost on what intake to get, maybe a Edeldrock RPM? I know I am going to get a custom cam, I just do not know where I am going to get one. Any suggestions? I have been searching the forums exhaustively and no one really has a definitive answer on what will produce 400rwhp with a 347. Thanks for the help.
:SNSign:
OrangeMustangGt
1,976
Cape Cod, MA
Aug 2, 2006
  • Aug 2, 2006
i would say afr 185's, systemax 2 intake, custom cam....with ~11:1 compression internals
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 2, 2006
  • Aug 2, 2006
Is emissions an issue?
I would use victor jr heads with either a holley/TFS R/Victor 5.0 manifold, custom cam, valve springs, 1 3/4" longtubes, 3" mid pipe ect. 400rwhp is simple but if you use mediocre parts you get a slow mediocre combo
Use at least 4.10 gears and use an aluminum flywheel.
Heres a fairly easy way to make 466rwhp out of a n/a pump gas streeter 347.. http://www.corral.net/forums/showthread.php?t=820761
FastGT02
22
  • Aug 8, 2006
How much does it cost to convert the stock 302 block to a 347 minus cam, heads, and intake? im talkin parts?
I
igotyofire
774
Southern California
Aug 8, 2006
  • Aug 8, 2006
thats a question best answered by your local machine shop as to achieve a 347 u will need them to bore/ and possibly balance the new stroker kit, and id probably let them assemble the shortblock as well.
Kronos
101
the boondocks
Aug 8, 2006
  • Aug 8, 2006
i thinki speak for i few when i ask is there any way to give just a rough guess as to how much a stroker would cost.
Davin
1,353
Jacksonville, FL
Aug 8, 2006
  • Aug 8, 2006
NO there is not.
It's just b/c when you stroke, there are so many options/issues - oil pans/coolers, radiators, oil pumps, girdles etc. You can do the Hot Rod mega cheap thing, or the high performance built to perform and last thing..so many variables....
Anyway to the original question about 400 rwhp. Your in luck b/c there are many 347 owners here these days. My first reaction is what do you want to do with that hp. You noted that you wanted it to still be good for the street..hmmm how much tack time do you have and how important is it to you? I know that my 347 does not have 400 rwhp (which is only a peak value anyway) but I wouldn't trade it for one that did b/c mine is built for being fun on the street and has low end torque to spare. First be very clear about its use and lets go from there..(read - you could build one but you might not like it)
TrueBlue95GT
966
Connecticut
Aug 8, 2006
  • Aug 8, 2006
Here is how much my shortblock costed:
88 stock block: $100
AD performance rotating assembly: $999
FTI custom camshaft: $350
Machine work: $1300
Main support: $100
Bearings and stuff: $150
Total: $2999
And that's not counting the heads, intake manifold, injectors, oil pump, timing chain, fuel pump, roller rockers, etc....it's not cheap.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 8, 2006
  • Aug 8, 2006
If you go custom cam
Your GUY will discuss all the specifics and make combo recommendations based on your goals or expectations you give him ... so ... get specific about what you want
Grady
doobsstang
92
Pembroke, NH
Aug 9, 2006
#10
  • Aug 9, 2006
  • #10
Davin said:
NO there is not.
I am in the same boat as you. I do not have that much of an interest taking it to the track. I want it to be a fun driveable street car. 400hp was just something that sounded good to me at the time. I have been reading a lot about peak hp and tq. I like the idea of trying to shoot for that, sounds much better. Sounds like a fun car to drive. What is your combo? I just am kinda torn on doing an H/C/I or 347. I like the idea of more cubes, and I like the idea of the H/C/I being cheaper. But if I do something to my car I want it to be done right. It will be stored for the winter and will be done at the same time as my AODE to (TKO600 or GFORCE) swap. Need any more info? I just want the SOTP feeling and being able to keep uo with an LS1...
:SNSign:
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Aug 9, 2006
#11
  • Aug 9, 2006
  • #11
mikes on point here.....
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Aug 10, 2006
#12
  • Aug 10, 2006
  • #12
TrueBlue95GT said:
Machine work: $1300
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 10, 2006
#13
  • Aug 10, 2006
  • #13
:SNSign:
well, if you do the 347, the h/c/i swap will be a necessity anyway or you will have wasted a ton of money on a motor that will perform horribly. if you dont have any or limited interest in taking it to the track, and your bottom end is in good shape, i would recommend afr 165's, an fti custom grind cam, and an edelbrock performer. with a good tune you will be at 300whp if not slightly more. if the block is in need of repair, Grn92LX pretty much nailed it.....
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
