351?
  • Thread starter Thread starter ShAkE N BaKe!!
  • Start date Start date Aug 15, 2007
ShAkE N BaKe!!
144
  • Aug 15, 2007
I have a '65 and I was looking into putting a 351w and have stumbled onto someone in my neighborhood with a 69 cougar, which has a 2bbl 351w he's willing to sell for $225. It comes with with everthing from intake to pan. Is a '69 351w a good year? Can I still use my power steering?
My plan is to get a 351w, master rebuild, GT-40 heads, mild cam, I cant find any intakes, carb. and MSD ignition system, Hooker LT headers and Flowmaster exhaust. What would be a good hp estimation?
69gmachine
576
Southern Maryland
Aug 15, 2007
  • Aug 15, 2007
Yes, the block is a good casting, just make sure it's not cracked or already bored out to 040 or more. The GT 40 heads are no better than whats already on it, so I wouldn't bother with the swap. I'd sell the heads on ebay for a $100 and use that towards some aluminum heads like TW or AFR 185s.
ShAkE N BaKe!!
144
  • Aug 15, 2007
can I install a roller cam in a 69 351w block?
brianj5600
1,964
Middle TN
Aug 15, 2007
  • Aug 15, 2007
You would be better of with a 94+ block. At the power level you are talking about, any block will do.
D
danny clemens
728
  • Aug 16, 2007
Yes but it ain't gonna be cheap.
ShAkE N BaKe!!
144
  • Aug 16, 2007
I need some help.
I checked it out and it only has the crank pulley. Does anyone know what brakets & pulleys I need? And where or from what car can I get them from?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 16, 2007
  • Aug 16, 2007
The C9OE and D0OE 351w heads are the same basic casting as the GT-40 iron heads and I think the aluminum GT-40 heads use the same design. If both heads are ported the same, then they would flow the same. From what I understand, the stock GT-40 heads will outflow the stock 351w heads. I could be wrong on this.
ShAkE N BaKe!!
144
  • Aug 17, 2007
Just bought the motor and it only has the crank pulley. Does anyone know what brakets & pulleys I need? And where or from what car can I get them from?
G
Gud T.B. Blown
583
Aug 17, 2007
  • Aug 17, 2007
You need the pulleys and brackets for the accessories you plan on using. At the bare minimum you need an alternator bracket (the alternator already comes with the pulley) and the pulley that fits over the water pump. If you plan on using power steering or a/c you will need pulleys and brackets for those as well.
Google and ebay are tremendous rescources for information and parts.
D
D.Hearne
11,730
south louisiana
Aug 17, 2007
#10
  • Aug 17, 2007
  • #10
According to Ford's 5.0 book, they're not the same castings. In developing the late80's GT40 heads, they first sent Jack Roush a set of E7's to port and polish. The result was a head that flowed more than the original 1960's GT40 head (this was a race only piece), so they went back to the drawing board and designed the late 80's GT40 head. So in effect, the 69-74 351W heads aren't in the same class as the 80's GT40 iron heads, the only thing they share in common is the valve sizes.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 18, 2007
#11
  • Aug 18, 2007
  • #11
That is very interesting. I've been told that the 69/70 heads, if ported properly, will flow equal to a GT40 head.
D
D.Hearne
11,730
south louisiana
Aug 18, 2007
#12
  • Aug 18, 2007
  • #12
Yea, I don't know. Get Ford's 5.0 book by Al Kirschenbaum and read the chapter on the GT40 development, that's where my info comes from. If not just for that, this book is loaded with info on all the 79-2001 5.0's, not just the Mustang 5.0's. Summit Racing carries this book, it was put out thru Ford Racing originally.
'69Stang
1,130
Metro Detroit
Aug 24, 2007
#13
  • Aug 24, 2007
  • #13
D.Hearne is right on the GT-40's......
Sell the GT-40's for $400-$500 and buy a set of AFR 185's, you won't be disappointed.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
I'm a new member...
  • Badcatt
  • Feb 4, 2023
  • The Welcome Wagon
The Welcome Wagon Feb 19, 2023
Badcatt
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
