351c rebiuld question
  • Thread starter Thread starter BIGJUNE
  • Start date Start date Jun 15, 2004
BIGJUNE
17
LOS BANOS,CA
Jun 15, 2004
  • Jun 15, 2004
i have a 351c and i needed advice on what options do i have on pumping this motor up during the rebuild? im more familiar with the 351w motors . is there stroker kits for these too? need help want more power than stock . its going it a 73 coup.
dodgestang
1,360
Cecil County, MD
Jun 15, 2004
  • Jun 15, 2004
Anything you can do to a W you can do a C the only limit is you.
What is your budget and performance desire?
I built a mild 408c that puts down 400 RWHP through an AOD and a Ford 9 inch with a hydro cam and under .6 lift....10.6:1 compression and with a low rise single plane intake.
BIGJUNE
17
LOS BANOS,CA
Jun 15, 2004
  • Jun 15, 2004
ok thanx
Mach1steve
95
Burlington, Ont.
Jun 15, 2004
  • Jun 15, 2004
mine was good too !
I built a standard bore & stroke 351C, 4V Holley 650 Dbl pumpr, 560 lift Hyd Cam, 10.6 to 1 comp, Roller Rockers, Windage Tray (cheap Hp), Single Plane Torker, Stainless steel 1 peice valve.... it is amazing... guessing at 380 to 400 rwh.
without a stroker kit.
Drive nioce on the street, though runs a bit hot.
Mach1steve
www.muggziperformance.com
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
