351C SWAP TO 429/460
since the 429 was available in the 71-73 mustangs, the mounts are around which makes the swap easier. you will need a 429/460 specific transmission though as the bel housing is different from the 351c t the 429/460 blocks.
Like they said, the 385 series was an option for the big body Mustangs, so engine and transmission mounts are available. You will need a 351M/400/429/460-specific bellhousing and/or transmission. Yes the C6 is good, but it's heavy and sucks up a lot of power. Perhaps that is not much of a concern with a bigblock...
One more thing, TURN OFF YOUR CAPS LOCK.
Had a 351C? Did you blow it up?
Those motors can make nasty, nasty power. Do some google searching on the CHI 3v heads.
I'd keep it and build it up.
Good luck...
Posted via Mobile Device
