Here is my situation:
The 351w in my 67 GT Coupe lost a con rod bearing.....so it needs to be rebuilt. Money is TIGHT.
I have a 96 351 roller block.
Trick Flow stage 1 cam 0.498/0.512" lift
Edelbrock Performer RPM heads with 1.90/1.60 valves.
Edelbrock Performer RPM intake
Quick Fuel Pro Vac 750 carb
Speed Pro 1.6 roller rockers
Summit SFI balancer
Ram Billet Flywhell
etc....
SO.......I am going to buy a rotating assembly......but which one and what size?
My heads are very limiting for strokers.......I may be able to sell them to a friend and get some Vic Jr's......but doubtful.
I really, really was impressed with the combo in my little 67 on the street.......pulled very strong up to 6000rpm limiter.
I know many will say it is under cammed and too small heads, but there was something with this combo......it kills on the street!
That is why I am really leaning towards rebuilding it to a 357.......not stroking it.
I would use scat cast crank or a stock crank turned down to cleveland mains, scat or eagle H beams, and nice forged pistons for my little 357.
What would you do? Keep in mind that I do not have the funds for AFR or other expensive heads, not untill we pay off the GT vert we bought!
Summit SFI balancer
Ram Billet Flywhell
etc....
But it costs to experiment. If you're satisfied with the performance, I'd only change the necessary parts--bearings. Maybe replace the mains too while you're in there.
