Hi- I've got a '69 vert with a 351w that was running fine, then sat at a body shop for about a year.
Took the trans (FMX) off for overhaul, and when I was putting it back on, the engine was pretty hard to turn with a bar on the crank nut. As I was putting the bolts back in the flywheel, the last 1/4 rotation was REALLY tough, but I got it to turn far enough to get the bolt in. I just wrote it off to the compression.
Now, several months later, the engine won't budge at all. I've torked on the crankshaft nut as hard as I could, and tried the starter. It's an auto so the "roll it and pop the clutch" trick won't work.
What do you think? I thought rusted rings, so I sprayed quite a bit of PBlaster penetrant in the spark plug holes. No fix. I'm getting ready to pull the heads and hit the pistons with a block of wood.
Any ideas???
Any ideas???
