- May 18, 2015
- 16
- 1
- 3
Hi, everyone i am new to the forum and have seen alot of good info on here so i decided to join and see if anyone could shed some light on my problem. I have a 1991 mustang LX orginially a 4 banger all parts have been swapped from a donor 1987 GT or were purchased new, mostly new. My issue is fitting my 351w stroked 427 dart block into the k member of my 1991. all swap parts were used and the motor was built specifically for this application by myself. My issue is my oil pan which is a moroso 20529 seems to be sitting on not the k-member but rather the powersteering rack before my mounts (which are energy suspension 4-1124G) are fully seated onto the k member. Seems the engine would need to come down about another 1/4 of an inch to be in, so i figure im off by about 3/4 - 1 inch in spacing from rack to oil pan. The pan is made for this swap and i was told when contacting moroso that the pan it should fit no problem, i have measured the pan and it is the correct dimensions. Running a big cowl hood so no clearance issues up top but cant say the same for the bottom. Any help is appricated, Thanks for reading and i can supply any info to anyone who needs it.
