351w Harmonic Damper Spacer
Best bet is to call the manufacturer of the balancer.
I installed a Fluidamper, which needed a spacer for the pulley, and called them. They gave me the March part number. About 5 years back, so I cant remember the numbers.
I agree, call the guys that made the balancer.
You will also need to tell them what front belt system you are using. I assume it is the stock setup from the 93 in your sig?
When I built mine I ended up with the wrong spacer. I had to have it machined down about .250"
jason
well its a 4 cylinder, so i dont think im gonna be able to use any of the belt systems from it. I was think about getting a complete setup from March Pulley's. My dad owns a machine/fabrication shop, so machining stuff wont be a problem.
