351w oil pump?
witch replacmet pump is better? what whould be the best? whats the diffrents beteween the 2 mellings pumps? btw im going with a HV pump... i need to get one for my 418w stroker witch should i get?
Melling Oil Pumps
689-M83HV Ford 351W High Volume Oil Pump
OR
Melling Select Oil Pumps
689-10833 Ford 351W Oil Pump
25%+ more volume than OE
OR
FORD RACING
397-M-6600-B3 Oil Pump 351W High Volume
all the pumps listed are probly made by melling, as far as volume, ide rather "WASTE" a little hp on extra oil flow than to be 10 lbs short at 6,500 rpm cause your oils hot and you bearings are broken in, you have car insurance right? so why not have a little extra oil"insurance" remember that oil not only lubes the bottom end BUT also cools it so the more oil that washes and lubes the bearing surfaces the better i run .0015 on my rods and mains with 10-40 kendall an have 50@idle and 70-75@ 6,000
