351W question
  • Thread starter Thread starter tvmax1962
  • Start date Start date May 27, 2006
T
tvmax1962
  • May 27, 2006
On the front of the cam where the timing gear and fuel pump eccentric go there is a pin that inserts thru these and into the cam. Is it normal for this pin to be able to go into the cam so deap that it does not enguage with the eccentric anymore? Should I just push the pin in untill it is flush and then put in the bolt? What holds in the pin or keeps it from slipping in further when the motor is running? Should the pin be longer? It is a comp cam camshaft.
Thank you
Jim
dennis112
1,561
36
79
Amish Wonderland of Central PA.
May 27, 2006
  • May 27, 2006
Thank you
Jim
Normally Comp supplies both the 2 pins with their kits. One is longer than the other. It sounds like the one you have is the short one and you need the long one to engage with the eccentric.
You really need to get the right pin. What ever you do, don't just partially put it into the camshaft. The correct pin will press fully into the cam and still reach the eccentric. The washer under the eccentric bolt helps keep it all together.
How much too short is the pin that you are using?
D
D.Hearne
11,730
south louisiana
May 27, 2006
  • May 27, 2006
One quick fix is to insert a ball bearing into the cam behind the pin. Drive the pin in after it, that will put it out far enough to let the pin engage the eccentric. Or just use a later 2 pc. eccentric, the center stamping has an ear folded in to engage the hole in the cam gear.
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Push rods are loose
  • keel
  • Jul 24, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2023
slow84lx
M
  • mnky99
  • Sep 5, 2025
mnky99
M
D
Electrical Manual 2003 GT 4.6L coupe that will not start. Thoughts? Resources?
  • DapperFish
  • Jan 17, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2024
PSKSAM2
P
