98blackstallion
It's actually easier to tell what WON'T swap between 5.0 and 5.8.
Intake lower
Fuel rails need longer crossover hoses
Distributor
Oil pan
Just about everything inside the block
Pushrods
Head bolts
Heads if they were originally from a 5.0 unless you enlarge the head bolt holes.
Balancer from a post 82 5.0 HO is 50 oz vs 28 oz (Same with flywheel/flexplate)
The balancer/flywheel/flexplates will all interchange fine, but balance weight must be matched to engine...
Headers will bolt up fine, but may not fit chassis.
Edit
Speaking of chassis...
The 5.8 is 1" taller than the 5.0, so hood clearance is of concern.
The 5.8 is about 2" wider if memory serves...
Intake lower- check new intake
Fuel rails need longer crossover hoses- check new rails
Distributor- check 95 bronco
Oil pan- check ford swap pan
Just about everything inside the block---done
Pushrods---gotta wait to measure for these.
Head bolts----got these...
Heads if they were originally from a 5.0 unless you enlarge the head bolt holes.....gotta do this yet..
The balancer/flywheel/flexplates will all interchange fine, but balance weight must be matched to engine......Check new balancer and flywheel.
Headers will bolt up fine, but may not fit chassis...check hooker super comps
car has a 2.5" svo cobra hood on it so hood clearance is good!
