351w swap
  • Thread starter Thread starter ls1beater4eva
  • Start date Start date Jan 9, 2008
1 of 2 Next Last
ls1beater4eva
334
mooresville
Jan 9, 2008
  • Jan 9, 2008
ok well im getting ready to do my 351w swap into my coupe and was told that there is a dizzy out of a 351w to run so i dont have to buy a aftermarket one from somewhere does anybody know what year dizzy i need and what is it out of
hllon4whls
BANNED
2,567
Covington
Jan 13, 2008
  • Jan 13, 2008
If you want to stay fuel injected, any ford truck fuel injected dizzy will work. If not, get a duraspark III type if you are going carbed. You will need the right type of drive gear to match your cam type (roller or flat).
85ragtop
BTW, I like dudes.
475
123
NC
Jan 15, 2008
  • Jan 15, 2008
This falls under 5.0 tech.
Thread moved.
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 15, 2008
  • Jan 15, 2008
If its EFI get a late 90's TFI 351 dis.
88mouse
630
Mooresville nc
Jan 15, 2008
  • Jan 15, 2008
He's got a 94 351w roller block. But he's not sure if he is going carb or injections.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
  • Jan 16, 2008
not just any dizzy will work. i have write up on this in the usefull technical thread sticky.
http://forums.stangnet.com/showthread.php?t=687004
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
  • Jan 16, 2008
BTW for your info only certain dizzy's work with the vic jr intake. So it is worth while if you plane on ever running that intake to buy something that will. This is the trouble I'm running into now.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
  • Jan 16, 2008
what is the trouble with the intake? is it hitting somewhere or something?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
  • Jan 16, 2008
The edelbrock guys recommend having the 8478 part numbered dizzy from MSD. I have this 8485 part numbered dizzy it is wider then the recommended dizzy by a little over a half inch. Msd says to use PN 85805 dizzy for a 351w running a vic jr. It is 7/16 of an inch taller then the current dizzy I have. I'm worried that I will end up having to buy a new msd dizzy if I want to run a vic jr. I guess I'll just have to bite the bullet and go see if mine works.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
#10
  • Jan 16, 2008
  • #10
is the collar at the bottom wider or something? i dont see where the cap would hit? well msd makes a small diameter caped dizzy it is part #8478
you have part # 8485? thats a VW dizzy?!?!
goodfastncheap
100
Bellevue, NE
Jan 16, 2008
#11
  • Jan 16, 2008
  • #11
Subscribing.
I don't know if the OP will be running a VicJr. -- and not to threadjak, but I am shopping for a Vic Jr. right now...guess probably my DII isn't going to fit?
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
#12
  • Jan 16, 2008
  • #12
yea of course they do because you have to run a msd digital box with it and its a mechanical advance dizzy. the one i listed above is a vacuum advanced dizzy. if you already have a msd box then it is the better one.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
#13
  • Jan 16, 2008
  • #13
Sorry I have PN 8584. I didn't think I was dyslexic but maybe I am. It is the basically the same as the one MSD lists as the one you need to run with the Vic Jr but my dizzy is 7/16 shorter then the one they say you need to run. I wonder if anyone has run this dizzy with the vic jr.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
#14
  • Jan 16, 2008
  • #14
Double post. sorry
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
#15
  • Jan 16, 2008
  • #15
7/16 from the collar the the shaft end or to the top of the dizzy? if its shorter to the shaft end it might not make it to the pump from the mounting surface of the victor jr!! that might be why they say you have to run it. didnt think about that. in that case im screwed to because i am going to want to swap to a victor EFI spider one day. damn now i got to get a new dizzy too.
EDIT: from the looks of it the EFI 351 swap dizzy will not work with a victor EFI intake. i will call tommorrow and get exact dimensions.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
#16
  • Jan 16, 2008
  • #16
http://www.msdignition.com/pdf_catal...log_69-111.pdf
Go to page 13 of 43 and 14 of 43 to see the 3 dizzy's I'm talking about and there size.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
#17
  • Jan 16, 2008
  • #17
linky no worky.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
#18
  • Jan 16, 2008
  • #18
ok go to msd.com then to 2008 free catolog then to download catologe then to distributor section
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 16, 2008
#19
  • Jan 16, 2008
  • #19
http://www.msdignition.com/pdf_catalog/2008_catalog_69-111.pdf
there that works.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Jan 16, 2008
#20
  • Jan 16, 2008
  • #20
i will check it out in the A.M. but obviously they are making one for a TFI/EFI application. i see people running the spider and EFI all the time. they re on 302's though but that shouldnt make a difference in base hieght. oh well i will give them a call and let you know.
1 of 2 Next Last
K
351w engine swap
  • Killer351w
  • Jan 21, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 21, 2026
Killer351w
K
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
J
1996 v6-v8 swap
  • jujuonurmom
  • Oct 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2025
jujuonurmom
J
