351w swap
ls1beater4eva
334
mooresville
ok well im getting ready to do my 351w swap into my coupe and was told that there is a dizzy out of a 351w to run so i dont have to buy a aftermarket one from somewhere does anybody know what year dizzy i need and what is it out of
If you want to stay fuel injected, any ford truck fuel injected dizzy will work. If not, get a duraspark III type if you are going carbed. You will need the right type of drive gear to match your cam type (roller or flat).
The edelbrock guys recommend having the 8478 part numbered dizzy from MSD. I have this 8485 part numbered dizzy it is wider then the recommended dizzy by a little over a half inch. Msd says to use PN 85805 dizzy for a 351w running a vic jr. It is 7/16 of an inch taller then the current dizzy I have. I'm worried that I will end up having to buy a new msd dizzy if I want to run a vic jr. I guess I'll just have to bite the bullet and go see if mine works.
is the collar at the bottom wider or something? i dont see where the cap would hit? well msd makes a small diameter caped dizzy it is part #8478
you have part # 8485? thats a VW dizzy?!?!
Sorry I have PN 8584. I didn't think I was dyslexic but maybe I am. It is the basically the same as the one MSD lists as the one you need to run with the Vic Jr but my dizzy is 7/16 shorter then the one they say you need to run. I wonder if anyone has run this dizzy with the vic jr.
7/16 from the collar the the shaft end or to the top of the dizzy? if its shorter to the shaft end it might not make it to the pump from the mounting surface of the victor jr!! that might be why they say you have to run it. didnt think about that. in that case im screwed to because i am going to want to swap to a victor EFI spider one day. damn now i got to get a new dizzy too.
EDIT: from the looks of it the EFI 351 swap dizzy will not work with a victor EFI intake. i will call tommorrow and get exact dimensions.
i will check it out in the A.M. but obviously they are making one for a TFI/EFI application. i see people running the spider and EFI all the time. they re on 302's though but that shouldnt make a difference in base hieght. oh well i will give them a call and let you know.
