351Windsor heads VS E7TE heads
stevesLX
373
cincinnati
O.K. guys I currently have E7TE heads on my motor right now that have a 3 angle valve job and have been ported. I have the opprotunity to pick up a set of 351W DOOE heads from a guy for 50.00. He says they are eith 1969 or 1970. He is not sure and he thinks they are stock. So with that info is this going to be an improvement over my E7's or not? And is there anything I should pay attention too when I look at these other ones. I am new to this.
That's a hard call to make, honestly. They may not offer any improvement over your ported E7's if they're stock, but they probably do have more potential if you plan on doing some port work to them. If I recall correctly, they are one of the better factory castings, but you may end up putting enough money into them with machine work that a set of aftermarket heads start looking more attractive for the money spent, IMO.
Stock for stock the 351 heads have bigger valves and breath much freer than E7s (if we're talking about the D0 series heads). They should have 1.84/1.54 valves compared to the E7's 1.78/1.45 valves. The down side is i believe they have a slightly larger combustion chamber so you might lose a little compression, but not a lot. If you take them to a shop to have them cleaned up you can have them milled down some to boost compression on them.
I have a set of C90E's which are the '69 heads, these are the ones everyone looks for when you mentioned old 351 heads. I got them with some pretty extensive port work and 1.94/1.60 valves but a few valves were bent. I took them to a local shop to get new valves done and the guy there said he hadn't seen port work that good in a long time since a lot of people just do CNC porting now.
Either way for $50 i'd say they're worth a shot....the only thing you have to keep in mind is if they're '69-70 heads, they're going to need valve guides for sure because back then they used leaded gas to lubricate the valves....you'll need to use newer style guides since you're not running leaded. If you're going to do that you might wanna just go ahead and get a valve job done while you've got the valves out, so you might expect to put a few hundred into them...so that's your call.
