360 HP on a GT with...?
merc123 said:
Can you get 360 RWHP with:
4.6L SOHC
Mild cam
Straight pipes
Hi-Flow cat
GT40 heads
Underdrive pulleys
With those exact mods, NO. But, you could get pretty damn close with the same amount of mods or similar. This is a video of a 321rwhp N/A 03 GT. Mods are:
-V&M Stg. 1 heads
-Comp Stg. II Cams
-Full exhaust (LT's, O/R H, Flows)
-CAI
-70mm TB & plenum
....thats it. With more aggressive heads and cams, better flowing catback (POS Flows :notnice:), and maybe even an X-pipe....you could see around 350-360rwhp :drool: :hail2:
VIDEO:
http://www.need2speed.com/Movies/321rwhpNatAspmustangGT.WMV
-V&M Stg. 1 heads
-Comp Stg. II Cams
-CAI
-70mm TB & plenum
VIDEO:
It also has mach1 pistons so the compression ratio is like 10:1
4.6L SOHC
Mild cam
Straight pipes
Hi-Flow cat
GT40 heads
Underdrive pulleys
1. Are you going to have the block machined to accept an in-block cam or are you going to have the GT-40 cams converted for SOHC operation?
2. If the latter, which head are you going to put the mild cam in?
3. Are you going to have your Mac H converted into a Y for the high-flow cat? Or are you going to keep the H and put the mild cam on the side with a stock convertor and the PI cam on the side with the high-flow converter to balance things out?
4. WTF is going on here?
BTW, this is quite possibly the worst thread ever.
The 281" 4.6L Mod motor is not a good powerplant to make lots of N/A Power.
With the most popular bolt ons, Full Exhaust, pullies, timing adjuster, Air Filter, Cold air intake to include plenum and throttle body, most cars I've seen only put down 250-265 RWHP. With cams and a tune mabey you could reach 300 RWHP.
With that being said the correct suspension, gearing, weight reduction and the basic bolt ons, a 99+ Mustang is capable of 12's.
If I were to do it all over again, I would've purchased a used GT, paid for a Forged engine rebuild and got a supercharger.
