363 Long or Short block
  • Thread starter Thread starter Brent Francis
  • Start date Start date Jan 31, 2022
First Prev 2 of 2
from6to8
There's suction so I used that end O_O
1,897
142
94
Aug 5, 2025
#21
  • Aug 5, 2025
  • #21
Noobz347 said:
It is only a rule of thumb and there are a ton of variables that go into it but...
500 FWHP / 400 RWHP are both used to describe the theoretical range where it starts getting iffy.
With an N/A build, you're talking about a lot of RPM for 500 HP.
With a boosted build, Tuning mistakes, over revving, and lean fuel at the top, all lend themselves to revealing a weak 2-bolt main.
Again though... None of this is written in stone. The test for me has always been:
What kind of money am I putting into this block? Do I trust the block to keep the guts inside at the power levels I'm shooting for?
If it's close, spend the money on the upgraded block. If you got blocks laying around like pet turds in a yard... Meh... spares are good.
In either case, I would opt for the better block. Even if I'm doing a 500 HP N/A build, It would be solid lifter, light weight valve train, and I'd want to rev it to the moon (because is sounds badass).
Question for you and @AeroCoupe -
I'm just thinking out loud on a potential 363 build for the 94 at some point after the 95 is done and here's a short list of what I'm thinking. This will be just a nice fun weekend car for the most part, no track.
Dart 363
Performer 2 or SM2 ported
likely a 185 or 195 head
SC ( Why would I want a SC over a Procharger? I think I like the look and fitment of the SC and I'll also still run AC).
Will keep my current 1 5/8 LT headers
I know I'll need an upgraded fuel system IIRC? I think the car still has the stock pump on it and does have my modded 302 engine in so that'll be perfect to upgrade the pump if it doesn't kick out before then lmao. Then again at 268 K when I got the car they likely probably changed the fuel pump before maybe a few times; just not sure what's in it.
As for suspension it already has subframes , J&M rear adjustable lower arms, all of the bushings and ball joints are redone and up to date, tokiko blue shocks and struts, CC plates.
Anything else for the suspension I'd need to do and anything else need added to the list let me know. I left out all the other things like meter and TB but right now those aren't important on the list. This is just a feeler to see about when I potentially do something. I thought about just doing an NA 363 and maybe I'll hit 420-430 ish but with the blower and not crazy boost I should be able to hit 500 to the wheels from combos I read up on yesterday.
The 331 build I think I'll be somewhere around 340-370 and with a fresh engine I'm sure that'll feel a lot better than around 300 in the 94 right now. The Terminator is around 500 at the least to the wheels and so 420-430 ish might be ok; I'll see
from6to8
1,897
142
94
Aug 5, 2025
#22
  • Aug 5, 2025
  • #22
Then again this guy hit 500 at the wheel NA. I got to research the combo more but off top of my head it's a carbed Dart, 11.1, Edelbrock 195's I believe, cam is 235/243 .575-.577 on a 112lsa,
View: https://www.youtube.com/watch?v=87_nyjoCttQ&t=590s
AeroCoupe
6,072
4,173
183
Claremore, OK
Aug 5, 2025
#23
  • Aug 5, 2025
  • #23
A good NA 363 should be 500 rwhp without any boost (Ford has a crate motor that builds 500+ fwhp so a custom built motor should exceed this easily) and north of 650 with boost. I would run a minimum of a 205/225 head on a 363 but that is just me. The cam would be a solid roller and custom ground.
Reactions: Noobz347
from6to8
1,897
142
94
Aug 5, 2025
#24
  • Aug 5, 2025
  • #24
I actually spoke to Mark, the owner of the car in the vid thru messenger earlier and he shared his build specs and details on the car. He said it is very street-able even at low rpm's and I actually think I'd feel comfortable mimicking his build, though I'd be FI vs carb. His heads are actually Vic Jr's at 210cc and I might have mis stated earlier if I said 195's. I'd feel comfy going with those as the price does not look bad vs going with a TF or AFR 205. He said the Vic Jr will outflow any head in it's range.
Why solid instead of a roller or just your preference?
AeroCoupe
6,072
4,173
183
Claremore, OK
Aug 5, 2025
#25
  • Aug 5, 2025
  • #25
So for me it's being able to get up into the 7000+ rmp range and you do not have to adjust the lash all the time with good poly locks and if you run girdles on the rockers. You can run steeper ramps and high lift so with the proper cam selection you will make more hp.
Why not just run the Holley Terminator X?
Admin Dude
Jan 4, 1985
43,317
21,501
234
Box behind Walmart
Aug 5, 2025
#26
  • Aug 5, 2025
  • #26
I am also a believer is large heads.
I've heard all the arguments about lazy air etc... and the dyno s on that theory in just about every case.
from6to8
1,897
142
94
Aug 5, 2025
#27
  • Aug 5, 2025
  • #27
Are you speaking in terms of software in running the holley?
from6to8
1,897
142
94
Aug 5, 2025
#28
  • Aug 5, 2025
  • #28
But it's all about properly matching the combo with those larger heads correct? Because just because someone has a set up with larger heads and the dyno numbers look good, it might be not so fast at the track LOL?
Admin Dude
Jan 4, 1985
43,317
21,501
234
Box behind Walmart
Aug 5, 2025
#29
  • Aug 5, 2025
  • #29
You're building a stroker.
That aside, even a stock 302 shows an improvement with larger heads and valves. It's all about filling the cylinders.
Now, you [can] choke it off with an anemic inlet tract and wreck the whole thing.
AeroCoupe
6,072
4,173
183
Claremore, OK
Aug 5, 2025
#30
  • Aug 5, 2025
  • #30
Kind of. Its is the operating system but its also the newer tech in the chips, boards, ect. that allow it to do more. I really feel like once you get past a 306 the stock ECU even coupled with a chip or QuarterHorse just has its limits. A 363 inch stroker is not cheap and then a person tops it with 30+ year old tech for fuel injection makes no sense. Spend the money and get a good injection system that has the ability to get the performance out of the motor. From what I have read the Holley has a huge following with lots of support.
from6to8
1,897
142
94
Aug 5, 2025
#31
  • Aug 5, 2025
  • #31
Yeah I will study up a little bit more on the whole thing about the Holly because all I knew of was the software with tuning and the intake and stuff. I think I read some stuff where they got the fuel systems and all that stuff but a little bit I've read it seems like depending on what you're doing with the car has to spending all that extra money.
So some people would say it'll run good enough with the stock ECU tune and fine for what they wanted to do but sure I get the other side of it as to getting the most out of it for what you're putting in the engine.....
I'll have to see numbers of total cost buying all of the necessary parts the Holly stuff and then getting it installed. Matter of fact buddy of mine is doing a 440 right now and he bought the Holly harness and the software stuff. He paid the 300 bucks to do the online course or training of it but he said it's just too much for him right now and he's trying to get the car ready for mustang week so he's going to get a remote tune done.
He's more of a track guy but after doing a 331 347 and 408 and having things happen to each one of them he said he's not really going to do the track stuff anymore. I will definitely if I get the Holly be doing remote tuning and probably do plug in everything plug and play versus trying to wire stuff in and all of that so yeah
from6to8
1,897
142
94
Aug 5, 2025
#32
  • Aug 5, 2025
  • #32
I'd like to have a verbal conversation with you about this lol. If you want to PM me your number or I will PM you mine whenever we get time one of these days we can have a chat.
Admin Dude
Jan 4, 1985
43,317
21,501
234
Box behind Walmart
Aug 5, 2025
#33
  • Aug 5, 2025
  • #33
View: https://www.youtube.com/watch?v=jqeDuOZtYPs
For this test, they used the same cam across the board in order to compare apples to apples.
Now, apply to that a custom ground/selected cam to make use of the larger heads.
Reactions: WhiteCobra95
First Prev 2 of 2
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
