393 stroker CR help?
351vic
33
Pierz, MN
Hey guys, I'm putting together a 393 stroker, I have the bottom end already but the guy i got it from said it would be 10.5 CR and I just ran all the numbers on the compression ratio calculator and I came up with 11.3:1!:eek: So therein lies my dilemma.... Is that WAY too much compression for the street with aluminum heads or will I be okay? Thanks
11.3:1 is a little high for the street even with aluminum heads. combustion chamber volume is the best place to adjust compression if you haven't already bought the heads. i'm assuming the heads have either 58 or 60cc chambers and if you went with a 64cc head instead you'd probably be closer to the 10.5 number. either that or run a really thick head gasket
Clevelands love compression, having said that, you also would not want too much for the street on pump gas. I had my extra engine rebuilt to match Boss 351 engine specs for my 71 Boss. The CR is 11.3:1 on iron heads, but I run on the street octane booster, 93 pump gas, and take it easy on the timing. NO problems whatsoever, so far :D .
Also, the cam grind you use can help you run on the street.
I get 11.18 - my spreadsheet takes in one or two more variables, chiefly piston to wall volume. You can run this CR if you also choose a healthy cam to bleed off some dynamic compression. If I were you, because I am not a can expert, I would consult with a custom cam grinder.
