  • 2005 - 2009 Specific Tech
4.10 Gears...Again!
  • Thread starter Thread starter FL2005GT
  • Start date Start date Jul 14, 2006
F
FL2005GT
100
  • Jul 14, 2006
I know there are a bunch of posts out there, but I couldn't find this info. I'm specifically looking for input from 5-speed GT owners with 4.10's.
1) Rating of 1-10, 10 being highest, what do you rate the seat-of-the-pants gain going from 3.55's to 4.10's?
2) Rating of 1-10, how bad is traction at launch with STOCK Pirellis?
3) With 4.10's, what are the redline shift speeds, in MPH, of 1st, 2nd, and 3rd?
4) With 4.10's, what is top speed?
Thanks!
ny in md
  • Jul 15, 2006
1) 10 seat of pants with M/T ET Streets
2)HORRIBLE!!!!! Tires not sticky enough want that power to move car not spin tires
3)When my shift light goes off I shift not looking at speed. I have it set at 5800 rpm so by time I shift I'm at 6200
4)ECU still cuts car off at 143mph as far as I know
5) ENJOY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
F
FL2005GT
100
  • Jul 15, 2006
Thanks!
I deleted the speed limiter with the tuner, wonder if it would hit 145 with 4.10's.
Sounds like I need to go with some fatter, stickier rubber out back. I wish someone made something like 275 55 ZR-17's so I could maintain stock look and ride height. Gah!
Fast05
409
Corpus Christi, TX
Jul 15, 2006
  • Jul 15, 2006
2) sucks, all they do is spin
3) 1st goes to 36, 2nd goes to 56, 3rd goes to 92 (i think) 4th goes to 116
4) i have speed limiter disabled and have taken it to 150 mph once, scary as hell, but 5th pulls pretty hard with these gears so yea it gets up there
ponygirl75
  • Jul 16, 2006
Thanks!
1) 20% more force to tire in 1st gear
2) ok with stock gears, slippery than eel sh$t with 4.10s
3) 4) I aint know but will do the math for you and get back to you
ponygirl75
  • Jul 16, 2006
1,2,3 gear speeds are 35, 60 and 90 respectively.
you'd reach top speed at 5th with 5050 rpm's @ 145 mph. Of course this assumes you're not electronically limited to something lower.
so in other words, your top speed will not be limited by your gearing, but by the hp of the car in relation to the aerodynamic drag loss and rolling resistance to friction.
D
Denny55
21
  • Jul 18, 2006
You should not hold high speeds with a 4.10 ratio as you may exceed the critical speed of the driveshaft.
F
FL2005GT
100
  • Jul 18, 2006
OK, thanks for all the info. What tires do you recommend out back if I go to 4.10's? I have the 17" rims.
brodude2002
42
South Florida
Jul 18, 2006
  • Jul 18, 2006
this is for a gt? bc thats about the speeds im getting when i redline 1st 2nd and 3rd, and i have a v6...
Rock36
76
Modesto, CA/Germany
Jul 20, 2006
#10
  • Jul 20, 2006
  • #10
Theoretical top speed, based on math equations, for a Mustang GT with stock tires and 4.10s at 6000 rpm is 174.15 mph.
You won't get to 174 without some serious extra power.
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
