  • 1994 - 1995 Specific Tech
4.6 VS 5.0 Difference
  • Thread starter Thread starter COBRA |2
  • Start date Start date Apr 9, 2005
First Prev 2 of 2
94GT40
110
#21
  • Apr 10, 2005
  • #21
Ruffrider said:
...but the 03 is smoother, more comfortable, and a lot better on gas than the 302 was.
Just curious what milage are you getting? I've been playing around with driving technique... Shifting at 2000 rpm, using 5th gear more, etc... and I just registered my best milage with the 5.0 so far... 24.7 mpg.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 10, 2005
#22
  • Apr 10, 2005
  • #22
Ruffrider said:
I've had a 5.0 and currently have an 4.6 so heres my opinion.
The 5.0 is a better motor if you want to mod. like H/C/I and not get reemed in the A$$hole with bills. The 302 is also MUCH easier to work on. It was my first mustang and I don't think the '03 GT will ever be as much fun as the '88 GT just for the fact that I was 16 when I got the '88 and was just so excited to have a fun car.
The 4.6 is in my mind a better motor all around if you are using the car for a daily driver. Not that the '88 GT wasnt a good daily driver, but the 03 is smoother, more comfortable, and a lot better on gas than the 302 was. Only downside to the 4.6 is the amount of money it cost to mod the car, and the fact that I don't trust the internals for a second and I'm saving for a new shortblock at this very moment. Also didn't like the lowend but a set of 3.90s cured that .
If it was up to me I'd have both motors, the 5.0 to mod the hell out of and the 4.6 to just drive around and enjoy myself.
A Q for you since you have experienced the mod motored Stang with steeper gears.
I've driven mod motored GT's, 05GT's and a 99 Cobra (drove it many different times and the most of em all).
I was dissappointed with the lack of low end torque from all of em.
I've always wanted to drive a mod motored Stang with steeper gears so I gotta ask you if you think the 390's on your Stang put it on a equal basis with a heavily modded 5.0 Stang as far as low end torque is concerned?
Later
Grady
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 10, 2005
#23
  • Apr 10, 2005
  • #23
Having owned both (check sig.) and drove others as well (DOHC, other 5.0L's, etc...and raced every example:
The common misconception of the 4.6L is the "lack of torque". The torque is actually registered down low as well but with the smooth powerband and higher rpm capabilites it fools the SOTP with the actual torque production due to the higher rpm's feeling more powerfull and less linear to the "down-low" torque of the 5.0L.
This is especially true in the case of the DOHC (Cobra's, Mach 1's) in that the powerband is even higher and you have a "building up" sensation to the SOTP even though you would very likely see the same dynoed torque numbers down low...it is a SOTP confusion...that is all
Just so you know: 94-95 5.0L will have the SLIGHTEST of edges against a 96-98 gt...only because of a slight weight difference. 96-98 Cobra's are on par with a 99+ Gt with a slight edge to the Cobra...
I personally prefer the 4.6L "platform" overall for a daily driver...the car had no problems and ran so smoothly. I have also driven some high mileage 4.6's and experienced the same smoothness. This has a lot to do with age as well but I prefer the 4.6L overall.
The aftermarket prices and quotes for 4.6L performance are dropping and getting closer and closer to competing more "fairly" with the 5.0L...
N
NUTCASE
187
#24
  • Apr 10, 2005
  • #24
50=teh win
cheap, easy to modify, easy to add cubes or replace with 351w.
but for some reason my 5.0 sounds half as mean as 4.6's that I leave in the dust???? I never understood that. they sound all nasty and scary and I'll all get intimidated but then I'll just plain pull on them with my bolt on 5.0 (fox body here)
one motor that is the shisnit. and ford motor sports needs to lower the price on it......the 5.0 cammer. its a dohc mod motor with the 4.6's 3.55 stroke and something like 3.7 bore. but its not just a bored out 4.6, its got the water jackets moved out and all types of nasty features
for my next project I wanna a 01 or 02 cobra and do the 5.0 cammer swap. add ported heads, cams, and a turbo. hy-a-bus-ays (sp?) look the **** out
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 10, 2005
#25
  • Apr 10, 2005
  • #25
My 2000 Gt with exhaust beat my 93 lx with all the bolt-ons/373's/electric fan/1.7RR's/full exhaust. The gears would allow me to out launch it with some sticky tires and then the Gt just had to play catch up and it did...
N
NUTCASE
187
#26
  • Apr 10, 2005
  • #26
hmmmm, mabey its just the drivers around me
5.0 gt hatch ........oh I'll just put it back in my damn sig
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 10, 2005
#27
  • Apr 10, 2005
  • #27
Yeah the driver has a lot to do with it. Atleast you understand that
A stock 99+ Gt will beat a stock 5.0L without much troulbe with a competent driver at the helm (Both being of equal skill)
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Apr 10, 2005
#28
  • Apr 10, 2005
  • #28
there is no such thing as a 2002 cobra
89Stang
4,178
Savannah GA
Apr 10, 2005
#29
  • Apr 10, 2005
  • #29
crap I mananged 28mpg on 87 octane averaging 75-80mph.
N
NUTCASE
187
#30
  • Apr 10, 2005
  • #30
ok so I don't know everything about the cobras, but I know there was a 01 with an n/a dohc 4.6
K
kolkid
79
#31
  • Apr 10, 2005
  • #31
as long as its a 5spd there great
well u are posting this in the 5.0 section so im thinking 5.0 will come out better go and post this in the 4.6 section and 4.6 will come out better
which ever one u get u will think that one is the best of the 2
First Prev 2 of 2
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
