After going back and forth on what I wanted to do (turbo) or a 408 build Ive decided to keep it N/A. This is something I want to put together for next spring/early summer so as of now I want to get everything planned out as for what I'm going to need so I can get a cost est on the whole project. I dont want to get down to buying all the parts and then at the last minute getting this and that for $150 here and another $230 there when I didn't plan on it. So with that said here is the outline of the project and what I plan on buying. If I am forgetting anything please let me know. I want to get the compression to about 10:1
- CHP 408W Scat based engine kit +.030"
P4082F-SCA-30-F408 - Ford 408W Dish Top -24.0cc Scat-Based Engine Kit
- AFR 205 Heads ( I assume I want the 58cc with the pistons in that kit for higher compression?)
- Edelbrock Victor 5.8 Intake + porting by Tmoss
- Accufab 90 MM TB (converting to a fox set up)
- Using the Current FTI cam ( with a valve spring Upgrade)
- Kooks long tube headers, what size headers should I go with? (undecided on a mid pipe)
- Lifters (not sure on what I should get for lifters..suggestions??)
- Push Rods
- Roller Rockers (currently have Trick Flow 1.7's, are these fine to reuse?)
- Engine gasket kit
- Injectors, Currently have #36's, should I upgrade?
- High flow oil pump, Ford Racing
- Water pump, reusing my stewart High Flow
- Reusing current valve covers
- Reusing timing chain, brand new as of last summer
That's everything I can think of as far as stroking my 351 to a 408. If there is anything that I am forgetting that I should get let me know. The bold text is areas I have questions on.
Thanks
Travis
- Push Rods
- Engine gasket kit
Thanks
Travis
