41/91
Micheal Nadeau
258
32
49
Savannah, GA
I know this has been covered. This one isn't a what's wrong. My 02's are shot, car runs rich as sin, sensors indicate lean. Aside from my EGR (deleted) codes, the only ones I have are the 41/91. My question is this: What sensors do I get or does it matter? I.E. Bosch lists two different part numbers but doesn't specify if they are specific to any one bank. My car was originally an AOD car. Its now a T5 and running an A9P. I know there is some issue regarding wiring harness'. Also, being as I don't have catalytic converters, would I benefit from adding the 02 extenders (the bungs that screw in to move the o2 sensor out of direct air flow)
Just want to make sure I don't over look something or tear anything up. After swapping motors and replacing a few sensors, she seems to be running pretty strong.
Nope, left and right are both the same. I find Denso tends to make a better O2 though.
As long as you have the correct transmission harness, you should be ok.
That would be an extremely bad idea. Don't do that.
Reactions: jrichker
Those bungs are voodoo. I can't see why anyone would want to move the sensor away from where it was intended to take its reading.
My coworker did that on his car to get it to pass emissions and I still have no idea why that seems like a good idea.
He probably did it to the downstream o2 sensor. When a vehicle is throwing a P0420 check engine code , for catalyst efficiency, people will move the downstream o2 sensor out of the path of exhaust to slow down the sensors response time. Doing this, in this particular case, will simulate the catalytic converter actually working correctly. I have seen this done, and done this myself, to get my own vehicles through state inspection.
The idea with moving the O2 sensor was to see if it would alter the way it read the exhaust and maybe tell the car it was rich, and in return the car would attempt to lean itself out. In the two years I have owned it, it has always been on the rich side.
Seeing as I have went through and replaced every other sensor in the car......
It started running funny before the motor went. Wouldn't start and stay running cold. Started having a hesitation issue. I fought with a idle surge, idle hunting, the start and die when cold and now a hesitation/misfire. I literally have tested and replaced every sensor that I know of. Distributor and TFI replaced, ECT was good, ACT replaced, TPS good, IAC good, MAF replaced, BARO replaced, 10 pin connectors cleaned, vacuum leaks checked for, battery voltage is good, cleaned grounds and regrounded. I think everything except my hesitation/misfire is fixed. And the 41/91 codes remain. Its frustrating because I am a diagnostic tech, yet seem to keep getting my a ss kicked by EEC-IV.
More stuff that you probably have seen before, but relevant to what you are doing...
Code 41 or 91. Or 43 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 6-Oct-2014 to improve code 41 description due to clogged Thermactor air crossover tube
Code 41 is a RH side sensor, as viewed from the driver's seat.
Code 91 is the LH side sensor, as viewed from the driver's seat.
Code 172 is the RH side sensor, as viewed from the driver's seat.
Code 176 is the LH side sensor, as viewed from the driver's seat.
Code 43 is not side specific according to the Probst Ford Fuel injection book.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
a9x-series-computer-connector-wire-side-view-gif.71316
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (L\RH O2 with a dark green/pink wire) and 43 (LH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 29
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports. This puts an excess amount of air in the passenger side exhaust and can set the code 41. Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
Thanks jrichker.
Reaching here, is it possible that my intake could effect this. I swapped my gasket matched lower intake for a ported lower. Could I actually be getting that much more air now, and my car is actually functioning correctly? I didn't have the 41/91 before the rebuild.
Michael Nadeau said:
........and I definitely did not fix my cold start issue. Fires right off, hits about 1800 rpms then plummets and dies. Anyone want to buy a car....... I'm starting to think my lower intake gasket moved on install.
You mean like this?
photodisplay.php
Vacuum leak due to slipped lower intake manifold gasket...
Ask Nicoleb3x3 about the intake gasket that slipped out of place and caused idle and vacuum leak problems that could not be seen or found by external examination. I don't care what you spray with, you won't find the leak when it is sucking air from the lifter valley. It simply isn't possible to spray anything in there with the lower manifold bolted in place.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface. Also use the weather strip adhesive on the side of the gasket that mates to the head. When you are done, the head surface and the gasket surface that mate together will have weather strip adhesive on them. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with Blue Silicone gasket sealer and put it together. Bingo! no leaks, and no gaskets that shifted out of place.
I wasn't thinking quite like that. That looks like a pretty cheap gasket as well, I have nice thick gaskets.
I replaced my O2 sensors. Replaced the PCV and also pulled my injectors and plugs. The hats on some of my injectors were cracked or broken, so I replaced them and the O-rings. None of the plugs had signs of actually running lean, or rich for that matter. I think I may try replacing the coil. I know I can throw a spark checker on it and see if it jumps .030 or .040. But the issue has been while under a load. I have a steady 39 psi fuel pressure at idle. At one point I thought it was fuel related, but it ran great a higher rpm's and speeds. It hesitated at low speeds and rpm's. I dunno.
To date, Baro, MAF, ACT, wires, distributor and tfi, O2 sensors, pcv, injectors (serviced), grounds, tps adjusted, IAC cleaned, fuel induction service. Any one have any other ideas......?
Any difference in the engine running codes?
Can you get the cylinder balance test to run, or is the engine too sick to run stabilized at 1450-1600 RPM?
