- Feb 14, 2016
- 2
- 1
- 13
Hey whatsup guys,Im new to the forums here, but not new to stangs. I have a new build in mind. looking to go 418w, afr 225's, eagle competition rotating assembly(unless someone can suggest a known better rotating assembly) flat tops,14:1-15:1 cr, comp cams 318dr solid roller camshaft,jesel shaft rockers. Will be a strip nitrous motor. Dont know which block to go with(definitely not a stock block),curious about the Dart shp blocks and what their limits are, as well as the iron eagle blocks. Obviously will be using race fuel, dont know if I should go carb or fuel injected with engine management. Opinions would be great and Im open to suggestions let me know what you guys think.
