Just wondering as I know a large majority of 94-95 guys (well those running the CBZA/J4J1 anyway for load settings)are/have already gone to a larger injector (42lb being the most common) and a larger MAF (PRO-M being the most common). Is there a faq on this for changing the necessary variables in the tweecer? I know you have to change the injector slopes (high and low), do the MAF function and just upload the PROM42 file for the MAF file transfer (or do the conversion and input the numbers if you going off the actual prom-m sheet that came with the MAF).
The only other possible adjustments in this category may be:
*Injector breakpoint setting?
*Battery versus Injector offset setting?
*Anything else?
*MAF Tranfer/leaning for adjustments
I realize that every car is differernt even with the same parts installed, but it would be great to have a listing (a-b-c for starters) and then (d-e-f) is where you should look at and tune to your car's requirements.
Thanks for any information...
*Anything else?
...... CBAZA FAMILY ONLY
