94mustang gt, it sounds like maybe you left a line loose or disconnected or something. If you're smelling THAT much gas then I'd say it's probably spilling out somewhere. So it's probably running rough because it's not getting all the fuel it needs, NOT because it's getting too much fuel. Check your fuel pressure. Check and make sure all the injectors are seated properly. Make sure the lines are fully connected properly. Make sure the regulator is seated properly. Let the engine run while you're looking for the problem. If a full tank is getting you just 45 miles then it has to be a significant and obvious leak somewhere. Good luck...
