450rwhp?
snoboardcore
276
New Hampshire
Hey guys im currently at 357 rwhp with my set up and i want to be around 450 rwhp. Im now installing a blower cam, 42lb injectors 80mm maf gonna be running 7-9lbs of boost will this put me there? also what else would help me out to reach this?
what super charger is it? paxton? i didn't know u could run it at only 4lbs boost, i thought it was like 8 at the lowest... did u get any power numbers befor u added the blower?? just curiuos, because your set up is almost the same as mine, minus the blower, and i have an E cam - thanks pal
Its possible to run the low boost #s... Boost is only pressure...
So, lets say a blower make 8psi on a car with stock heads/intake... take the stock heads away and add some big ol' aftermarket heads along with a higher flowing intake.. then what do you have? More room for air to fit in! So, the pressure from the boost will go down to a lower number like 5 psi.. The blower will essientailly produce the same Volume of air into the engine, just not at the same pressure.
Imagine trying to blow through a coffee straw, and then a big cardboard toliet paper tube... Big difference on the backpressure uh? Some idea with the small heads vs. large heads... pressure goes down.
