4r70w guys chime in
Devin7717
Nebraska
Im looking to pull the t56 out of my 99 SRA cobra and go auto instead of building t56 only to go auto down the road anyways. First off I plan on going fmvb with a trans brake so It won't need to be automatically controlled, so what will I need to make the swap. Also I'm currently running 4.10 gears on a 100-150 shot and plan to go turbo in the near future. Doing some reading it's made to seem as though it'll be tough making a full 1/4 mile pass with 4.10s and staying out of o/d which you're not supposed to use under WOT. I am planning on having freddy brown do the transmission. Sorry for any obvious or stupid questions, I'm new to the auto thing.
One of the Mega builders on here ( @CarMichael Angelo ) has a 4R70W that is full manual- I’m pretty sure it’s a Transgo kit that uses a vacuum modulator to replace the computer control- then you wire up some switches for Od and Tc lock up .
I’m not sure how you are tuning the car,but I would guess you could disable or correct for the transmission change in the software.
Edit here’s the kit-http://www.transgo.com/products.php?category_id=76&parent_id=30&product_id=132
Just buy a trans brake manual vb, if you're using a reputable builder he'll know what to do/ recommend. If you're building a drag car,..( and if you're gonna have a TB VB you are), you should look at a different transmission ( like a C-4) where you can Gear the car for the turbo and not worry about keeping it out if OD.
