  • 1994 - 1995 Specific Tech
5.0 forced induction help
  • Thread starter Thread starter sk8fate
  • Start date Start date Nov 30, 2010
First Prev 2 of 2
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 21, 2010
#21
  • Dec 21, 2010
  • #21
A turbo can blow a stock 302.
Yet...you want this kid to invest in a 306 or 347? Why? So he can piss away his money that much faster when it goes BOOM?
Do your research before u commit to anything. Do not take 1 guys advice. Look at the guys that are actually doing it(not just saying they are)...pick their brains. Search message boards. And take everything with a grain of salt. Then form your own opinion. And buy your mods.
4jenna is someone you want to meet, talk to, and take notes from
9
95cobra svt
18
#22
  • Dec 21, 2010
  • #22
Its better to bore it over or atleast get supporting parts and spend more money now to make it as reliable as possible then just throwing the turbo on the stock 302 and blowing it up and then having to go back in and spend money on a motor when you could of made the motor strong enough in the beginning. the 306 kits with the 8.5:1 compression do really good with blowers or turbos. They're a kit the specifically made for running a blower or turbo
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 21, 2010
#23
  • Dec 21, 2010
  • #23
opcorn:
Grady
H
HollisArmstrong
26
Alabama
Dec 21, 2010
#24
  • Dec 21, 2010
  • #24
If you're looking for a less expensive turbo and want to run trins why not go remote mounted turbo?
Squires Turbo Systems - Turbocharged Innovation!
Hollis
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 21, 2010
#25
  • Dec 21, 2010
  • #25
So a bore or "supporting parts", will save the block? What about a stock block will cause it to blow? These motors are known to still be in great shape with high mileage. If u have problems, Ofcourse fix them. But if I say "turbo" and "stock"...I don't see the advantage of throwing money in the stock block.
I would rather turbo a stock block, cause I can get them cheap. If I'm going to invest in the block, I'm going to invest in a GOOD block. Not massaging over the stock block.
Turbos can make too much power, too easily, to justify spending money on a stock block shortblock that can not handle the hp reliably. Regardless of what crap you put inside of it.
If that works for u....great! But machining/cleaning a stock block for a 306, or 347, is a good chunk of change towards a good block. And you spend all that and you don't even fix the issues!
Anywho, different strokes different folks. It's your money!
seijirou
2,417
DFW
Dec 21, 2010
#26
  • Dec 21, 2010
  • #26
I would never suggest anybody invest guts in a stock block and then turbo it. If you blow it up, you just destroyed those expensive guts too. The stock block is not strong, it's not a foundation for big power, and nothing will change that.
Big power the right way is also expensive, and there is no avoiding that.
If you want to make big power cheap, at least be honest about being cheap. You're rolling the dice.
So, if you're going to roll the dice, I would suggest leaving the block completely stock, and slapping on the turbo. If it blows, no money lost in the block, and the turbo setup will probably survive too.
BlackVert
5,589
9
98
Bethesda, MD
Dec 21, 2010
#27
  • Dec 21, 2010
  • #27
to make good power with a stock block, go with a stock 351 windsor block.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 22, 2010
#28
  • Dec 22, 2010
  • #28
I did pretty well with my last stock block.
Kurt
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 22, 2010
#29
  • Dec 22, 2010
  • #29
X2 on the 351w stock swap n turbo.
YEAHLOH95
1,249
EVERETT,PA
Dec 23, 2010
#30
  • Dec 23, 2010
  • #30
but a stock block weighs less so its going to be faster than those 351 and after market blocks , i say put 2 nice small t3/t4s on there with some 42's and have your friend plug his lap top into something and tune away
seijirou
2,417
DFW
Dec 23, 2010
#31
  • Dec 23, 2010
  • #31
Eh, the difference in weight is negligible.
The stock roller 302 is ~ 155 lbs.
The sportsman 302 is 165 lbs. (+10)
The sportsman 351 is 184 lbs (+29)
Or how about the siamese bore 351 from ford racing at 157 lbs.
But it'll set you back $4200
The factory roller 351, which is considerably stronger than the factory roller 302, is something less than the sportsman 351 in weight difference. If you can afford a stronger block, get a stronger block. Saving 30 pounds is no reason to give up the strength.
YEAHLOH95
1,249
EVERETT,PA
Dec 23, 2010
#32
  • Dec 23, 2010
  • #32
yes but them you add in all the 351 specific parts oil pan dist intake headers , all that adds up quick
seijirou
2,417
DFW
Dec 23, 2010
#33
  • Dec 23, 2010
  • #33
I don't think so. You could claim some pounds for the wider lower intake plenum, maybe 5. But those items you mentioned, I doubt there's even a pound of extra weight.
Point is, worst case, we're talking about 50 extra pounds and heaps of extra potential.
YEAHLOH95
1,249
EVERETT,PA
Dec 23, 2010
#34
  • Dec 23, 2010
  • #34
sorry i ment the cost of buying all those parts not the weight of them my bad
seijirou
2,417
DFW
Dec 23, 2010
#35
  • Dec 23, 2010
  • #35
Oh, yeah, it's not the way to cheap power.
First Prev 2 of 2
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
H
Transmission Help
  • Harman78
  • Feb 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 21, 2025
Harman78
H
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
