well, im scrapping the 5.0 hipo project! im still going to build my 5.0 but have acquired a set of aluminum gt40 svo heads.ive been looking at cams and.................still confused! ive looked at anderson n41,tfs stage 1, comp xe274hr. im not sure what to do! i have an edelbrock performer 289 4 bbl intake that i was planning to use. if i use one of these cams do you think at least a performer rpm or something equal?the performer is good to 5500 rpm and the performer rpm good to 6500. im trying to feel out a combo for fun driveability and zipper bulging midrange to around @ 6000 rpm max!i dont mind a mild lopey idle but its not important.with running a carb i wont be as limited as the EFI guys on the cam.with the alum heads ill be at @ 9.3 to 1 compression.so im thinking a smaller duration with more lift as to not bleed off too much compression.carb size @600-650 cfm.1 5/8'' shorty headers w/ x pipe to scavenge torque.it will be a five speed tranny with 3.50-4.10 gear depending on the cam.can anyone with experience with these types of builds lend some advice on the cam and intake selection that would match the heads and my build???thanks
