Mustang running very rough Any Help Greatly Appreciated.
i did upgrade to 24lb injectors but problem was there prior to the change as well
changed : distributor cap and rotor, also change the coil, spark plugs + wires, fuel filter, fuel pump, IAC, EGR,
still can't figure out the problem. also noticed the EGR + smog items dont have vacuum lines. could that be the issue?
also need help with a full diagram of the vacuum lines (preferably a video)
also runs really rocky/rough on step of the pedal may be due to stretched throttle cable but was running like so before it became stretched, could it be a block in the exhaust such as a catalytic converter? as that bottom piece of metal did shave off at one point (car is pretty low) i ask because it pops on deceleration and if i revv it (or try too shall i say) it also pops it sounds likes its coming from underneath me/exhaust area.
