i see that in your one pic that u have cobra calipers for the front? could u give me a list of your parts for your front end?
i also notice that with the cobra calipers that there is no master cylinder in there. what size rotors are thoes for the front and with u having drums on the rear would u have to change the master with the bigger front brakes?
Here is my current list of everything i've purchased for this project. It's the standard 03-04 cobra 13in rotors with cobra calipers in front.
I'm going to try the stock MC and see how it works, if not i'll probably have to get a 93 cobra MC.
------Misc/Ebay------
2x 1994-95 V6/GT Spindles 150$ - *
4x 245x45x17 tires 550$ -
-----Maximum Motorsports------
1x Maximum Motorsports Brake line adapter (MMBAK-4) 7$ - *
1x Maximum Motorsports Caster/Camber Plates 87-89 (MMCC7989) 199$ - *
1x Maximum Motorsports Bump Steer Kit 87-93 Tapered Stud (MMTR-2) 149$ - *
-----Autozone--------
2x New 1994-95 V6/GT Hubs (513115) 108$- *
2x wheel cylinders - 20$ *
1x Drum Shoe Kit 20$ - *
-----Buy Ford Racing.com------
2x 10th annv. 2003 cobra calipers/brackets 260$- *
2x Stainless brake lines for cobra calipers 0$ - *
2x 13in brembo rotors 100$ - *
2x banjo bolts/washers 0$ - *
2x 5-lug 28T axles 249$ - *
2x 5-lug ranger drums 0$ - *
------Ford Parts Desk---------
2x rear axle bearing/seals (93 mustang) 57$ - *
4x 94 Mustang Strut Bolts / Nuts 33$ - *
2x hub to spindle nut 26$ - *
4x caliper to spindle bolt (N805163-S190) 28$ - *
1x Friction Modifier (M19546A) 4$ - *
-----Breeze Automotive-----
4x 16MM Front Control Arm Bolts 30$ - *
4x 16MM Front Control Arm Nuts 10$ - *
2x Spacer Washer for SN95 spindle/balljoint 4$ - *
2x Dust caps for SN95 hubs 10$ - *
-----Pro3i-----
1x Pro3i Street Lower Control Arms (PRO3-SLCAS) 170$ - *
------Summit Racing------
1x Bullitt Style Suspension (Struts/Springs) (M5400A) 419$ - *
1x FMS Front Control Arms (M3075A) 215$ - *
------Late Model Restoration-------
1x MAC Rear Support Cover (MAC-28800) 120$ - *
3x 1QT Royal Purple 75W90 Gear Oil (RP-12300) 30$ - *
4x 98 Cobra Wheels (M1007D178) 460$ - *
1x Locking Lug Nut/Valve Stem Set (LRS-1012BK) 30$ - *
1x Drum Hardware Kit (LRS-H7246) 20$ - *
