5 speed trans ?
tranny
There are lots of questions that need to be answered before somebody can give you a good reply that can help. What motor for starters, I don't have the goods on whether or not it will bolt into the chassis, but it really depends on the powerplant you want to put it behind. Is it the stock motor? If so you can always fab the tranny mounts if need be. Also the bellhousing needs to be the right setup for the motor or have an adapter plate. Anyway, odds are it will fit in that year model with some mount changes.
Yes, it will work, but you'll need the Fox bellhousing and clutch fork. You'll also need a driveshaft spacer (I believe Steeda sells one) to make up the difference of the 5/8" shorter input shaft on the Fox T5 versus the SN95.
