50 series tires
50 refers to the height of the sidewall, that means that it is 50% of the width of the tire... 117.5 mm for that tire. That tire would be 27.25" high, which is way taller than the stock tires... it will make your speedometer off by like 5%. Sounds like a truck tire to me. Why are you considering putting these on the car?
Missinlinc:
There are "rev/mile" calculators available on-line and at TireRack.com. In fact, TireRack.com has a nice feature that allows you to "try on", electronically, different wheel and tire combos. You put in your stock wheel/tire combination and then it offers 18", 19", ..., etc. with the same or almost the same overall height. Check 'em out.
HTH,
Chris
