- Sep 26, 2004
- 184
- 0
- 0
Ok big question here. Thinkin about doin a head swap on my car, I have a set of heads that have a Stage 1.5 port job on them. Now what kind of cams woud I need??? Next question, could I put , with a good tune know, a 75 shot of NOS on my car? If so what kit would be the best? My car 02 Saleen SC 281, has the following mods....
Serias II Blower w/ Intercooler
BBK Long Tube Headers
BBK Off Road X Pipe
Bassnai Cat Back Exhaust
Accufab 75 MM Throttle Body
Lighting 90 MM MAF
42 lb Injectors
3:73 Gears
Cold Air Intake (Inside Fenderwell)
Aluminum Drive Shaft
Adjustable Clutch and Quadrent
SPEC 3 Clutch
10 lb Blower Pulley
MM Caster Camber Plates
MM Upper and Lower Control Arms
Ok I guess thats about it, that should help, um on a Mustang Dyno ( not a Dyno Jet) I put down 284 RWHP and 327 lbs of Torque, numbers from a not engine too. Now are thease good numbers? Another thing too the best time I have gotten at the track granted Im not the best driver or was it the best track. But I got ( on Nitto DR 15in Rims) a 12.9 at 106. I pulled like a 1.9 60 foot. Are thease good numbers or should I see more HP and lower times. Any feed back would be appreciated. Also any help in the mod questions I asked too. Oh yeah um can my blower work effectivly with ported heads or not, I mean will it still spool up ok, Im not gonna lose any boost am I? Well thanks for your time!!! Jake
BBK Off Road X Pipe
Lighting 90 MM MAF
42 lb Injectors
3:73 Gears
SPEC 3 Clutch
10 lb Blower Pulley
You should be putting down very good numbers!!
