65mm tb hurting me
bryce93lx
88
Luke AFB AZ
hey guys i have a 93 lx with dart pro 1 heads, cobra upper and port matched lower, e303, 76mm maf, 65mm tb, 24 lbers, 190lph pump,mac shorties and a off road h, and deleted smog, i am working the bugs out of the combo, and am wondering if you guys think i would see improvment with a 70 or 75 mm tb, i bought the tb when i was just going to leave it stock then i stepped up and could not afford anymore parts, thanks in advance
i dont know i have a set up kinda like your i had 19lb injectors turned up to 42 lbs and 65 mm throttle body and it ran like a champ, i just rebuilt motor and put my 65 back on and 24 lb injectors and it feels a little weeker, also before with old motor i put my 70mm on and it was weeker on bottom end and maybe a tad better on top end
I dont think the 65mm is a problem. 65 should be find.
65mm way better than the stock 52mm right.
what did you exspect from the motorcycle, the car may have 3 times the hp, but is 6 times the weight to carry.
