Route666
D.Hearne, I think WORTH's idea was to make peak pressure at 90* ATDC, to get maximum work out of the energy in the cylinder. This most likely would occur near the end of the fuel burn cycle as nearly all the fuel is burning at once but in a conventional motor by the time it is all ablaze, the CR has dropped a lot so you don't get peak pressure there, it occurs earlier.
If you could use the moving cumbustion chamber to hold more pressure longer, you would get more work out of it.
Man could you imagine seeing the individual combustion chambers on a V8 going up and down. HAHAHA it'd be comical, they shake enough as they are without external bits going as well.
Yes, in theory, but gasoline doesn't ignite instantaniously enough to do that, that's why ignition timing is advanced so far as engine speed goes up. The fuel needs more lead time to burn and have the maximum thrust on the crank at the right time. You're theory is fine, just not practical with gasoline. The fuel/air mixture is burning the whole time the piston is traveling down the bore, as proof of this, there is the unburned fuel/air mixture in the exhaust, even in a finely tuned motor, there is still some unburned fuel in the exhaust. As proof that your theory won't hold water, if you retard the ignition to where it fires the mixture when the crank is at mid stroke, or at 90 degrees in relation to the cylinder bore, which is what you're suggesting doing, the engine simply won't run.
Now go hit the showers.
