67 Carb and Intake question
  • Thread starter Thread starter LasVegas67Stang
  • Start date Start date Feb 10, 2004
L
LasVegas67Stang
11
Las Vegas
Feb 10, 2004
  • Feb 10, 2004
I have a 289 with the stock intake and carb. I would like to upgrade but not sure what i should go with. If i could get some Idea's ie Set up, Prices , where to find them , I would be very greatful. thanks
J.D.
steelhorse
369
The warm end of the gutter....Texas baby!
Feb 10, 2004
  • Feb 10, 2004
If your motor is pretty much stock i would go with an aluminum edelbrock 4barrel intake and a holley 600 carb.
intake-$200 - carb- $300 -- all new. then you'll need gaskets
Try summit or jegs catalogs
J
John Z
581
Morgantown WV
Feb 10, 2004
  • Feb 10, 2004
J.D.
Is the rest of the motor stock? If so, you will only see modest improvements from the carb and intake. You would need to improve the heads and cam to get that extra fuel into the combustion chamber and improve the exhaust to get it out. This is definitely a case where the you only get the true benefits of all the components when the system is balanced.
If I were you, as soon as I got the carb and intake installed, I would start saving for headers, cross-over pipe, dual exhust and low restriction mufflers. Then start saving for heads (rework or new?) and a cam.
Before I would start any of this I would run a compression test to ensure the motor is going to hold up to the mods.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
New to Mustangs/Fords
  • Joradan93Foxbody
  • Mar 2, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 2, 2026
Joradan93Foxbody
J
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
