67 Carb and Intake question
LasVegas67Stang said:
I have a 289 with the stock intake and carb. I would like to upgrade but not sure what i should go with. If i could get some Idea's ie Set up, Prices , where to find them , I would be very greatful. thanks
J.D.
Is the rest of the motor stock? If so, you will only see modest improvements from the carb and intake. You would need to improve the heads and cam to get that extra fuel into the combustion chamber and improve the exhaust to get it out. This is definitely a case where the you only get the true benefits of all the components when the system is balanced.
If I were you, as soon as I got the carb and intake installed, I would start saving for headers, cross-over pipe, dual exhust and low restriction mufflers. Then start saving for heads (rework or new?) and a cam.
Before I would start any of this I would run a compression test to ensure the motor is going to hold up to the mods.
