67 Super Snake Project
Tires Mounted
Got the 11" rears and 8" fronts mounted. (had 9 1/2" rears, replaced by PSE with 11")
Console
I started on the center console. I installed the electric window switched from Watson Street Works:
I installed the rear courtesy light and power outlet.
Interior Panels
NAPA Pro Stone Guard says it will "Match OEM Panel Texture". Looks very close. But you have to be about 24"-36" away from the panel when applying it.
Since the texture is white, I used a semi flat BBQ paint that looks very close to the normal color of stock panels! Not nearly as shiny as the other "Hammered" paint I was trying.
I am very satisfied with the results.
Tubbing & Rear Fold Down Seat
Wow, if I had known how much time would be spent on narrowing the rear seat by 2" (cutting, re-welding), cutting all the trim pieces, etc., I might have decided on just a rear tray.
But it is starting to come together.
I installed the Nitrous Switch and Speakers. I dont think speakers over 5 1/2" would fit in the console. I used a 2 way Infiniti Kappa. I just need the gauges, and then to wire it all up.
Now which mechanic in Dallas has a "Remove Before Flight" ribbon on his wall? It sure didn't show up with my switch!
TKO 600
Got the transmission out for test fitting. I bolted on the Shelby shifter, Lakewood Bell housing and transmission mount.
The hydraulic throwout bearing:
Built a bracket for the hoses from the the hydraulic throwout bearing:
And hoses to the clutch master cyllinder:
Center Console
I spent another 6 hours on finishing the console. I decided to put an electrical junction at the front of the console, use quick disconnect plugs for the speakers, power windows, and all electrical connections to ease the installation process.
There are quite a few wires under there!!!
Gret progress, Did you have any fitment issues with your lakewood bellhousing, All my friends who have installed them said the had to shim, and adjust things to get them toseat properly so not throw off the driveline. I saw a article about it in on ford muscle.com. I was just wondering since this week my TKO 900 and lakewood bellhousing should be in, thanks.
TKO 900? nice! Is it from MMR?
The bell housing fit very tight to the transmission. But I have not bolted it to the engine yet. I will still have to do the alignment procedures. As I understand it, due to engine manufacturers tolerances in regards to dowel pin locations, it can cause a bore misalignment that needs to be checked and corrected with offset dowel pins if the alignment is out by .005 .
I will also mount the headers to check for any clearance issues with the bell housing. It is a whole lot easier to fix it outside the car than after everything is installed.
Yeah, Its from MMR, i figured it should take what i was throwing at it. Yes I know from my friends that its better do all the final fitment before it goes in the car, other wise you swear alot more haha. Well good luck with it hopefully it doesnt require much effort to mount it properly. When do you think the car will be done?
Rear Speakers
I mounted the rear Speakers. Infinity Kappa's 6x9 3ways. I glued a 3/16 board to the back of the divider, cut out the holes, added carpet to the back, and then mounted the speakers.
Almost Ready for paint
Well, the car is almost ready for paint. A few surprises here though.
Biggest surprise, the front flares and fender rocker panels cut from the fiberglass fenders and moulded on to steel fenders.
Front nose is a bolt on piece now! The upper nose piece was by far the most time consuming.
Rear end caps have nice and tight gaps.
And they are bolted on.
Upper and lower side scoops, rocker panel and rear flares finished.
I'm going to Dallas on Monday to check it out in person!
Vent Wings
I rebuilt the vent wings. Even after many hours of polishing, it does not remove the pitting. But it is better than it was. New rubber inside, on the front door edge, and new felt lines the window channel. The only special tools need to repair these items is a narrow rivet gun, and a small punch (I used a small drill bit) to drive out the roll pin to replace the wing locks.
[EDIT] I just couldn't put a pitted part on the car. I disassembled them and took them to get plated. $250 :jaw:
Radio Bezel
I cut the bezel from the back using a cutting disc on my 4" grinder, twisted the piece out, and finished it with a die grinder.
Interio Vent Grills
I purchased the interior vent grills from Mustang Depot and mounted them in the sail panels. They fit very good.
