Better than a year ago my passenger window jammed, fortunately in the closed position. Today I thought I would try to see what got stuck, but it turned into a hassle as these "quick" projects usually do. After drilling out the three screws that hold the window rail onto the regulator track, I got the regulator and arms loose inside the door. The problem is that I don't know that trick for getting all that junk out through the access holes. Both the factory service and Haynes manuals simply say "remove the regulator." Do I have to take some of the scissor arms off or something? There is not a lot of room to wrestle that stuff around.
