69 Mach I engine compartment progress (DUW)
94CobraPace
907
Houston, Tx.
I'm redoing a 69 Mach I, 351W auto. I have the engine removed & am working on the engine compartment & suspension. Here are a few pics of blasted engine compartment & the black primered paint.
Now the black primer:
I will be painting the engine compartment black over the primer the correct flat black.
Question:
What is the color code for the correct flat black paint??? In PPG if possible
Thanks
geostang351 said:
Looks great! How did you remove all the crud and paint from the metal? Sand it, bead blast it, peal? :shrug:
Scrap, DA sander(ele) & then sand blast... What a pain in the a$$. Cleaned, then Ospho for the metal etching, clean with solvent, wipe again.
69Rcode_Mach1, I would rather not use spray paint, wanting to use automotive paint.
Needing paint code for PPG engine compartment paint..
Thanks
