69 w/ 429 CJS HELP!!!!
aug0202
I have a 1969 with a 429 CJS coupe that i had the fortune of getting my hands onto only problem is it needs a fuel pump the gas tank cleaned out because I am pretty sure that it is all jellied up. And the Carb more then likely needs some attention because it has been sitting for the last 8 years. The Carb is a motorcraft I am pretty sure it is original but not positive. Does anyone have some information or knowledge that can help me do this I also would like To know what I need to parts wise to get this done. Thanks
69s didn't come with a 429 CJ. Are you sure that's what it has? Did someone swap it in? Post some pics or a partial VIN. The 429 CJs came from the factory with Rochester Quadrajet carbs and the SCJs came with Holleys. None of them had Motorcraft carbs.
Well, the "Motorcraft" first appeared in 1972, when Ford sold Autolite™.
Of course, swapping a 429 into a 69 is no big deal. And clearing up the bad fuel, no matter what engine it is, is a matter of pumping or drawing the old fuel out, and pumping new fuel in. 8 year old fuel could darn near put a fire out, so replacing it is critical. Don't even try to run this thing with even a drop of the old fuel still in it.
I'm positive it has a 429 in it now where it came from that is good question I have heard rumors that Ford made special order drag packs which came with the 429 and beefed up drive train to match for that year. I have not run the vin on the car yet so I am not sure what it is supposed to have. or if it has been swapped out.
As for the Carb I'm not positive it is a Motorcraft that was strictly from memory and its been a month or so since I have looked at it
Do you have any ideas on pumping it out?
Remove the gas cap, then the fuel line at the pump (coming from the tank). Use an air compressor with a blower nozzle on the line, wrap with a wrag, insert the nozzle into the fill hole. The air pressure will force the fuel out of the tank thru the line.
The only 429 Mustang in 69-70 was the BOSS 429, with the NASCAR engine. These cars were structurally modified to accept the engine, and were sportsroof bodies.
Now, a coupe could certainly have had a 428CJ, or even a 428SCJ, and in mid 69 the cars with 3.91 or 4.30 rear axles had such things as beefed-up block assemblies and oil coolers, which became known as the Drag Pac.
Just give us the first 5 digits of the VIN and we'll know what's going on here.
alright i'll post some pictures tomorrow when I have some day light. Where on the engine can I get the casting a good shot of the casting numbers or vin? It looks exactly like the picture posted except for the sidfe mirrors.
Casting numbers are not critical. Well-lit sharp focus photos showing the intake, heads, and water pump would do the trick, especially with the air cleaner removed. Write down any casting codes you can find, though.
We also need the first 5 digits of the VIN. There's no way to evaluate the car without them, period.
alright here are a few pics i took them before i checked the boards and am going to take some more and post those as well forgive me i have just started to dig into it so the engine area is a mess.
[/IMG]
the vin on the chasis is a given i was trying to find the one on the engine and I can't see it. It might be covered with dirt and paint. Anyone have some clue because I already looked where I thought it was.
That's the 385 Series 429/460 ThunderJet V8 engine, which had a long service life, 68-94. Don't bother looking for a VIN on the engine, if you find it at all it won't be for your car. Nice conversion, though. The only 385 Series ever used in the Mustang was the 71 429CJ and 429SCJ. Look through the windshield at the dash for the VIN. It would be interesting to know what the original engine was.
