90mm?????? useless
consider what else you are going to do to the intake ? . . . simply putting on a larger throttle body will not net any gains . . . remember the stock MAF will still be a choke point . . . upgrading to a 76mm C&L MAF and 75mm Accufab are both sensible choices and really well made components . . . still, you really won't notice a gain until you swap out the intake . . . but it's a beginning . . . which seems to me to be what you are looking for.
Think about that.At 7,300rpms I will be glad I didn't listen to your "advice".![]()
for a RACE setup, ill understand that size but not for what this guy is looking for.....stick to the matter at hand
If you believe that then I suppose you will also believe that too big of a CAI will lose power over another smaller one.
Where did I tell him to go with a 90mm? Learn how to READ.![]()
You think that a stock size MAF and stock size TB are fine for a 5.0 with H/C/I?![]()
you think if i put my stock tb back on i will loose power?
I think if you do alot of things differently to your combo you would make more power. But to simply answer your question...yes. Also I pray to God your car runs faster than the time in your sig with a 125 shot.
