jbuening said:Do you know if the ACCEL throttle bodies will work that Summit Racing sells? IIRC they are around $400 and are 1000cfm+![]()
70_Nitrous_Eater said:Fuel filters:
You’ll want to run a fuel filter (or 2) in your fuel system. I chose to use 2 filters. A high volume low pressure (top) “pre filter” and a high pressure low volume (bottom) after filter. The larger filter is a generic summit brand and cost $10, the smaller filter is made by earls performance and cost $30. Both were ordered from summit racing. The key thing with fuel filters is to make sure they can handle the pressure and that they have the fittings you need.
Alternatives:
- No pre filter (saves $10)
- Only pre filter (saves $30)
66HertzClone said:Are you sure it is a good idea to use the Earl's filter you selected after the pump? At close to 40 psi or so, do you really want to rely on a couple of hose clamps to seal the lines.
66HertzClone said:Are you sure it is a good idea to use the Earl's filter you selected after the pump? At close to 40 psi or so, do you really want to rely on a couple of hose clamps to seal the lines. You might be better off using an OE filter from a late model Ford and the duckbill line connections. This stuff is shown on the Ron Morris web site.
I placed an order for this kit last week, http://www.mass-floefi.com/index.html I spent most of Saturday and Sunday going over instructions, wiring diagrams, and catalogs trying to pick out the best fuel pump and filters for my system. Dollar for dollar and from a safety stand point, the OE filter is real hard to beat, add in its size relative to the 5" by 3 1/2" monsters that others offer. If it is located carefully, nobody would know that is what you are using.
I'm not trying to be a wise guy, just trying to help, Jeff
rhyno9 said:66HertzClone
TBI systems/fuel injectors run between 15-20 psi so that filter and hose barb connector should be fine.
Nitrous Eater
Great writeup. I will be converting my fastback to efi using ms this winter as well.
When I put my board together I found that the 9 volt on the stim will not last very long. Use an old power supply for a cell phone or other device. Once the power drops off the 9 volt the squirt appears to do weird things.
Good luck
RV
68rustang said:could you post links to the auctions for some of the items you bought on ebay?
I need a connector kit like you have pictured as well as some of that fuel line.
68rustang said:Thank you for the links. I would rather deal with somebody that somebody else has had a godd transaction with vs a random seller. That is why I asked.
Thanks
NasaGT said:Great write up, looking forward to part 2!
Whew, I looked at prices for everything today. I have the throttle body and am going to buy 100 worth a month till I have everything. That's the plan anyway. I might wind up buying a new carb in the meantime. The carb I have now is blowing fuel out after the engine is shut off. This is happening below the fuel bowls somewhere. I'm figuring there is a crack in the carb's body somewhere.
Hells yes. Come on here looking for this thread, and it's right here. How cool is that ? Probably be the last time I take her out before doing this. Want to get a good handle on this before throwing the cooler on and more power. E85 I'm sure is going to just add to it. Thanx for the excellent write up Kalvin. I'm sure we'll be doing some talking![]()
