79 Brake Bleeding
  • Thread starter Thread starter koshe2
  • Start date Start date Feb 3, 2018
K
koshe2
  • Feb 3, 2018
I am working on a 79 pace car with 2.3 turbo. Been sitting 15 years or better and it has no brake pedal. I replaced the master and that didn't do anything. Unable to get fluid to get out of the bleeders, and the are not plugged. I even applied vacuum and nothing. I did some reading and some people talk about the proportioning valve could be causing me the issue. I see some bleeder tool on line and its for GM valves. Any help here would be great!
General karthief
Mod Dude
Aug 25, 2016
28,087
10,706
213
polk county florida
Feb 3, 2018
  • Feb 3, 2018
You did bench bleed the master cylinder? Of course you did.
Start by cracking the lines one at a time from the mc working your way back, that should show how you where your problem is.
Is your peddle going all the way to the floor, will not pump up,right?
K
koshe2
  • Feb 4, 2018
I did bench bleed the master. I have never ran into this issue before. The lined going from the proportioning valve are a challenge to get to to crack and I thought I would put it out there before I go further.
General karthief
Mod Dude
Aug 25, 2016
28,087
10,706
213
polk county florida
Feb 4, 2018
  • Feb 4, 2018
You have no fluid from any bleeder right?
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,078
224
Massachusetts
Feb 4, 2018
  • Feb 4, 2018
Something internall corroded or rusted out and is blocked. You'll need to crack brake lines loose and check for flow to isolate where the blockage is.
Reactions: Shakerhood
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 4, 2018
  • Feb 4, 2018
you are better off replacing all of the lines with new SS hard and soft lines. A car sitting that long will mos likely have he line rusted and the soft lines dry rotted.
2000xp8
Aug 8, 2003
8,061
1,647
194
NJ
Feb 6, 2018
  • Feb 6, 2018
While I hate working on brake lines, I agree.
The issue with brake lines is that it's never just one. One may get you by now, but rest assured, you will be doing all of them.
If you really want to see if the fluid is ever going through, crack all bleeders open, fill the mc to the top and check tomorrow. Gravity should make them leak.
Reactions: General karthief
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 9, 2018
  • Feb 9, 2018
If you need to replace any Hard Lines take a look at NICOPP Tubing, I recently replaced all the Hard Lines on a Pontiac Aztek and that stuff is amazing to work with, you can pretty much bend it with your hands, easier to flare than steel, and its corrosion resistant.
General karthief
Mod Dude
Aug 25, 2016
28,087
10,706
213
polk county florida
Feb 10, 2018
  • Feb 10, 2018
Repair a aztek?
Why?
Sorry, they are too ugly to fix.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 10, 2018
#10
  • Feb 10, 2018
  • #10
karthief said:
Repair a aztek?
Why?
Tell that to Walt
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 11, 2018
#11
  • Feb 11, 2018
  • #11
karthief said:
Repair a aztek?
Why?
Was certainly not in my plans, my Ex-GFs Son bought the car without letting me see it first and then I kinda got stuck making the damn thing road worthy, and that thing is a PITA to work on.
General karthief
Mod Dude
Aug 25, 2016
28,087
10,706
213
polk county florida
Feb 11, 2018
#12
  • Feb 11, 2018
  • #12
I hope it's not the awd version
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 12, 2018
#13
  • Feb 12, 2018
  • #13
It was a FWD, I can only imagine the AWD Version being even more of a pain.
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 12:24 AM
Shakerhood
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
